GTC-T SFP is coming Up
Nov 14th, 2008
In 7609 router i am using WS-X6724-SFP in that we connected 100mbps link through GLC-T copper SFP.But link is not coming up.But if i connected through switch and to router its coming up.
Please help me out to resolve the issue.
buchholr Fri, 11/14/2008 - 07:01
I would start at the physical layer. Make sure that you are using a crossover cable if connecting from router to router or from PC to router. If that doesn't work, try hard coding the speed on each side, it might be a negotiation issue.
Hope this helps,
chandru.j Sun, 11/16/2008 - 21:39
I tried with crossover also and i cant able to change the speed also.its supports only 1Gig only.
Giuseppe Larosa Sat, 11/15/2008 - 06:48
Hello Chandra,
I think that GLC-T copper SFP doesn't make the port capable to run at 100 Mbps.
I think it is only able to run 1000 Mbps full-duplex.
You need to use a native Rj-45 port with 10/100/1000 capability for this.
Hope to help
buchholr Sat, 11/15/2008 - 07:15
Giuseppe is right,
I double checked the compatibility matrix, and although this SFP is 10,100,1000 it doesn't work at any speed other than 1000 on the 6724 module.
Hi just wondering if anyone can confirm this. We have an SFP-T in a module in our 2821 router and are tring to connect this to a 100Mb Metroethernet connection and does not come. Plugging the Metroethernet into the system gigs works ok as i assume they auto negotiate to 100Mb but these are already in use.
Can you run a SFP-T at 100Mb if yes how ?
Many thanks
Jerry Ye Thu, 08/20/2009 - 10:02
Hi David,
Do you mean GLC-T or SFP-GE-T? The SFP-GE-T is 1GB only with extended operating temperature range and DOM support, and it is not supported to use with the 2800 platform.
Speed for GLC-T and SFP-GE-T can be verified with sh int cap command
Leo Laohoo Thu, 08/20/2009 - 14:20
GLC-T will only negotiate to 1Gb on a WS-6724 blade module.
I believe Edison mentioned something about the logic behind this is because no one from Cisco would image this blade to negotiate anything but 1Gb.
