Strange Ad-hoc
Nov 14th, 2008
We have a WLC 4404 witch 1131 AP's. On a few of them one of the ordinary SSID's is also sent as an Ad-hoc-SSID !
If I connect to the Ad-hoc-SSID and look at the client info in the WLC, the only info is:
Client MAC: xx:xx:xx:xx:xx:xx
Client vendor: Intel
Port: 0
Mobility role: Unassociated
AP Type: Cisco AP
SSID: N/A
Association ID: 0
Reason Code: None
802.11 Authentication: OPENSYSTEM
Policy type: Unknown
Encryption Cipher: Unknown
EAP Type: Unknown
NAC State: Quarantine
All AP's are configured the same way.
Anyone seen this before?
Steffen Lindemann Mon, 11/17/2008 - 04:47
My guess is that you are hit by "viral SSID" issue with Win XP SP2. Google search for the term to learn more about this.
The issue is that a client is setup in a wrong way, so the Win XP SP2 is setup to broadcast your SSID as ad-hoc. If a client near this computer sees it (and not your network) it will try to connect to the ad-hoc computer.
The only solution I found was to use GPO to push the profile to WZC and disable the clients possibilities to connect to ad-hoc network.
I never tried to look into the WLC for a status on hit clients, but I guess it could look like the one you are seeing (because of the similar SSID ??).
s.hellman Tue, 11/25/2008 - 00:38
Well, it doesnt seems so. if I unplug the power to the accesspoint, the ad-hoc SSID dissapears.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
