static route NOT to use a specific interface
Nov 14th, 2008
All,
Need to find a command on the router to define a static NOT to use a specific interface while it can use any other interfaces.
Jon Marshall Fri, 11/14/2008 - 06:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you be a bit more specific and give us an example of what you mean - are you talking about static route/static NAT etc..
Jon
yuhuiyao Fri, 11/14/2008 - 07:03
Here is an example:
ip route 192.168.1.1 255.255.255.255 NOT FE0/2.
Assuming the router has multiple interfaces, it can use any interfaces to route 192.168.1.1 except FE0/2
Jon Marshall Fri, 11/14/2008 - 07:11
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Still not sure what you are trying to achieve.
When adding a static route with a next-hop on an ethernet network the interface used will be the one that allows the router to forward the packet to the next-hop.
Jon
John Blakley Fri, 11/14/2008 - 10:28
  • Purple, 4500 points or more
I think your best bet is to use policy based routing. Based on destination, you can choose what interface to send the traffic out on.
Jon will have a MUCH better idea on how to set this up than me.
--John
John Blakley Fri, 11/14/2008 - 12:09
You could try:
access-list 10 permit 192.168.1.1
route-map NOFA2 permit 5
match ip address 10
set next-hop
If you want to drop the traffic from that address, I think you can do:
match ip address 10
set default-interface null0
Apply it to your inside interface:
int fa0/1
ip policy route-map NOFA2
HTH also
John
tcordier Mon, 11/17/2008 - 08:41
  • Bronze, 100 points or more
I think the easiest would be to define a static for each interface you want the router to use. The router will then load-share the traffic accross the different interfaces. The option to use Policy-based routing will make use of only a single interface at a time.
HTH, Thomas
