logging buffered
Nov 14th, 2008
The configuration for logging on a 1841 router is as following:
router#sh log
Syslog logging: enabled (1 messages dropped, 2 messages rate-limited,
0 flushes, 0 overruns, xml disabled, filtering disabled)
Console logging: level debugging, 168 messages logged, xml disabled,
filtering disabled
Monitor logging: level debugging, 0 messages logged, xml disabled,
filtering disabled
Buffer logging: level debugging, 168 messages logged, xml disabled,
filtering disabled
Logging Exception size (4096 bytes)
Count and timestamp logging messages: disabled
On the serial interface counters for abort and carrrier transition are >1000 and >270, last clearing of counters was 1d6h ago.
Since the last clearing of counters there is absolutely no entry in the log.
Why? Were the carrier transitions / aborts to short for beeing recorded in the log or do we have to enable a "higher level" logging?
Thank you for the answer,
Martin Funke.
Richard Burts Fri, 11/14/2008 - 10:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Martin
By default things like aborts and carrier transitions do not generate log messages. Changing the logging severity level will not do you any good. I have not done it on a live router and can not speak from experience. But the documentation looks like configuring under the serial interface: logging event link-status may get you the log messages that you want.
Give it a try and let us know how it works.
Rick
John Blakley Fri, 11/14/2008 - 10:25
  • Purple, 4500 points or more
Rick is absolutely correct. That will log up/down changes.
--John
