I'm after a bit of advice concerning the ASAS5505 with IP Plus. I am aware it can do redundant ISP links using a basic IP track. My question is if I have two of these will my IPSEC tunnels work and switch outbound routes ok?
I intend to have two ISP on one end and just 1 on the other end. In the event one of the DSL lines failed on the dual ISP and internet traffic failed over to the backup would I have any issues with getting my VPN to switch?
I have done something similar with a router in front of PIX before which worked ok using multiple peer addresses.
Thanks guys,
