Cisco 2821 FAN
Nov 14th, 2008
Please I need to replace the router's fan 2821 and don't find part number.
Can you tell me what is the part number in order to buy the item?
Thanks for your soon answers.
Have the following error in router:
ECGUQMP820#sh log
Sep 4 18:24:38.386: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:25:08.387: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:25:38.387: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:26:08.388: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:26:38.389: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:27:08.389: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:27:38.390: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:28:08.390: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:28:38.391: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
Sep 4 18:29:08.392: %ENVMON-3-FAN_FAILED: Fan 1 not rotating
ECGUQMP820# sh clo
Please confirm what i have to do with this problem, that is the cisco's output interpreter:
"%ENVMON-3-FAN_FAILED (x1): Fan [dec] not rotating
Explanation: The fan is not rotating properly.
Recommended Action: Ensure that the fan power cable is properly attached to the
fan power connector on the main board. If the problem persists, it indicates a
chassis that requires replacement."
Overall Rating: 4.7 (3 ratings)
Edison Ortiz Fri, 11/14/2008 - 09:03
If the device is under warranty, I recommend contacting Cisco TAC.
operaciones_redes Mon, 11/17/2008 - 11:45
Thanks for suggestion but dont have warranty.
Need the part number for order the replace unit... somebody can tell me the part number of the fan 1,2 or 3... or the fan's replacement kit for 2821??
Edison Ortiz Mon, 11/17/2008 - 12:16
I couldn't find a part number since when a customer reports a fan problem on such hardware, the entire unit is replaced.
operaciones_redes Mon, 11/17/2008 - 12:24
Please review the following url:
Document talks about a kit replacement for 2821 fans:
The fan replacement kit contains the following items:
•Fan unit (three fans connected together as one unit)
•Additional replacement screws (a few extra screws are provided in case you misplace the original screws)
•Installing and Upgrading Fans in the Cisco 2821 and Cisco 2851 Series Routers document (this document)
Can you confirm that??
Edison Ortiz Mon, 11/17/2008 - 13:05
I don't know what else to tell you. The document is there on the 'how-to' but it does not list any part number.
I've searched internally and externally w/o luck.
The only information I've received is the unit is replaced when a customer reports FAN problems.
buchholr Mon, 11/17/2008 - 20:15
This should be what you are looking for. Contact your Cisco partner representative for a price.
ACS-2821-51-FANS= Cisco 2821/51 Fan Replacement Kit
operaciones_redes Wed, 11/19/2008 - 07:02
Dear Rob,
Are you sure this part number exist??
I'm being looking in the cisco product list and doesn't exist..
My company is a cisco partner.
buchholr Wed, 11/19/2008 - 07:16
I originally found it on the Dynamic Configuration Tool, but I have also checked the pricing tool and downloadable price list under the ordering section. It lists for $100. Is your company set for direct ordering or through distribution?
operaciones_redes Wed, 11/19/2008 - 07:20
through distribution, i'm gonna look again in the price list..
thanks again.
Atte. Melissa Guerrero
