How to Change Utilization Threshold
Answered Question
Nov 14th, 2008
The current utilization threshold in DFM is at 40% for router's where can this vailue be increased?
Correct Answer by Joe Clarke about 8 years 4 months ago
To increase this, go to DFM > Configuration > Polling and Thresholds > Managing Thresholds. Then, select DFM > System Defined Groups > Interface Groups > Serial, and click Edit. Adjust the Utilization threshold, then click Save, then click OK. Then go to Apply Changes, and apply your changes.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Fri, 11/14/2008 - 08:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
russnash Fri, 11/14/2008 - 08:38
found it!!! Was in the neighborhood.
thanks for all tour help!!
