DFM Devices stuck at 10%
Nov 14th, 2008
I have an issue with about 340 devices stuck at learning state.
I have removed .Net 2.0 and 3.0 framework
I am running LMS 3.1 with DFM 3.1.0, I have already re-initialized the DFM database but
the devices are still stuck at 10%
Here are the steps I took to re-initialized database.
To reinitialize the DFM 3.0.x databases do the following:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=dfmInv dmprefix=INV
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=dfmEpm dmprefix=EPM
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=dfmFh dmprefix=FH
Delete NMSROOT\objects\smarts\local\repos\icf\DFM.rps and DFM1.rps.
Please help this is a new server that put into production last night.
Joe Clarke Fri, 11/14/2008 - 08:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Make sure there server's fully-qualified domain name is resolvable. Also, post the output of pdshow.
dionjiles Fri, 11/14/2008 - 09:09
C:\>nslookup hwpmg608.corp.citistreet.org
Server: hwpdc500.corp.citistreet.org
Address: 172.18.18.100
Address: 172.18.20.11
Is this is what you asking for?
Joe Clarke Fri, 11/14/2008 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This assumes that hwpmg608.corp.citistreet.org is the name that shows up under My Computer > Properties > Identification. If so, then this is fine.
The pdshow also looks good. Please post the NMSROOT/objects/smarts/local/logs/DFM.log and DFM1.log as well as the NMSROOT/log/dfmLogs/TIS/TISServer.log.
Joe Clarke Fri, 11/14/2008 - 10:26
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
DFM still thinks your hostname is HWPMG900. Did you reboot the server after making the hostname change?
dionjiles Fri, 11/14/2008 - 10:33
I sure did several times since last night around 6 or 7. How can I fix this?
Joe Clarke Fri, 11/14/2008 - 10:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Shutdown Daemon Manager, then delete NMSROOT\objects\smarts\local\repos\broker\broker.rps. Then restart Daemon Manager. This assumes that the COMPUTERNAME environment variable as seen in the output of the DOS SET command shows the correct hostname.
dionjiles Fri, 11/14/2008 - 11:18
Would it hurt to reinitialize the database again as well?
Joe Clarke Fri, 11/14/2008 - 11:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, but it shouldn't be necessary.
dionjiles Fri, 11/14/2008 - 11:40
I just performed those steps....so should I give it a hour or so to check back on it?
Looks like they are at 10% now....
Joe Clarke Fri, 11/14/2008 - 11:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Depends. What does the DFM.log say now? If the error about the old hostname has gone away, then I would give DFM some more time, else there is still a problem.
dionjiles Fri, 11/14/2008 - 12:13
Looks like hwpmg900 is still being a pain.....I will have to re-initialize the database I assume now.
Joe Clarke Fri, 11/14/2008 - 12:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No. Please post the output of "pdreg -l DfmServer" as well as the NMSROOT\lib\classpath\md.properties file, and the output of SET from a DOS prompt.
Joe Clarke Fri, 11/14/2008 - 14:33
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Change the value for the SM_BROKER environment variable under the system control panel, then reboot. The value should be:
HWPMG608:9002
dionjiles Mon, 11/17/2008 - 07:46
Thanks this worked and I'm up and running 100% now.
