1800 and 2800 routers and Access lists
Nov 14th, 2008
I have access list on my WAN ports that build tunnels over the internet. I want to apply even more security to those ports with out install a FW appliance. Any ideas would be great.
Giuseppe Larosa Fri, 11/14/2008 - 09:47
Hello Shane,
if you have or upgrade to an IOS release that support CBAC (Context Based Access Control) you have a feature near to a stateful firewall.
In modern IOS you should look for advanced ip services images for your routers.
As usual if you need to change the feature set this requires a payment.
Hope to help
netsquant Fri, 11/14/2008 - 10:18
I'm already running these types of access lists. I wondering if there is something in addition to for even more security.
John Blakley Fri, 11/14/2008 - 10:23
You can run IP inspects on the public interface, but this will cause overhead on your router. If the router is already heavily loaded, then this may not be a good option. In some IOSes, you can use IPS rules also.
Giuseppe Larosa Fri, 11/14/2008 - 11:20
Hello John,
ip inspect is the command to apply CBAC we are meaning the same feature.
Hope to help
netsquant Fri, 11/14/2008 - 11:24
i'm going to work on this in my lab to see if this is what i'm looking for.
I'll keep you posted.
