ASDM is unable to read the configuration from the ASA
Answered Question
Nov 14th, 2008
Hi!
I'm trying to connect to my ASA but i always get this error:
"ASDM is unable to read the configuration from the ASA. Please check the configuration and your connection and then try again by clicking the Refresh icon."
This only appears after I do the login in Java application.
This is from my "show running-config":
asdm image disk0:/asdm-507.bin
http server enable
ssh my.ip.from.outside 255.255.255.255 outside
http my.ip.from.outside 255.255.255.255 outside
I really need some help...
Thanks and Bests Regards.
Hugo Serrano
Correct Answer by rogernorton2 about 8 years 4 months ago
Hugo,
We've experienced the same error on computers updated to the latest JAVA patch:
JAVA 6 Update 10.
The problem does not occur on JAVA 6 Update 7, which we had installed previously.
Could be worth testing on a computer with the older release installed.
Roger Norton.
Overall Rating: 5 (1 ratings)
John Blakley Fri, 11/14/2008 - 12:13
  • Purple, 4500 points or more
Can you do a show flash?
John
hugo.serrano Mon, 11/17/2008 - 02:22
Hi!
show flash:
Initializing disk0: cache, please wait....Done.
-#- --length-- -----date/time------ path
6 5511168 Jan 01 2003 00:06:38 asa707-k8.bin
7 0 Jul 08 2008 07:27:38 crypto_archive
8 6161700 Jul 08 2008 07:30:28 asdm-507.bin
243679232 bytes available (11747328 bytes used)
I already tried with:
and
asdm image flash:/asdm-507.bin
But I don't think that the problem is there, because I can get the Java application in my Browser. The error appears when I log on and when I hit the refresh button.
Thank you!
Hugo Serrano.
Correct Answer
rogernorton2 Mon, 11/17/2008 - 02:41
Hugo,
JAVA 6 Update 10.
Roger Norton.
hugo.serrano Mon, 11/17/2008 - 04:06
Hi Roger!
Thanks a lot! That was the problem.
I tried with Java build 1.5.0_16-b02 and worked!
Thanks again. Best regards,
Hugo Serrano.
