Cisco ASA 8.x VLAN SNMP OIDs
Nov 14th, 2008
Hi guys, I own a pair of Cisco ASA 5510 running version 8.x of PIX-OS in an Active/Passive failover setup, configured as router on a stick with redundant interfaces.
shield1(config)# sh int outside
Interface Redundant1.100 "outside", is up, line protocol is up
I would like to meter incoming and outgoing traffic on all VLANs but I was unable to locate the correct SNMP OID to poll.
Anyone know if this is supported?
Thanx a lot in advance for you help.
Best,
Emanuele
Collin Clark Fri, 11/14/2008 - 10:47
  • Purple, 4500 points or more
Should be under interfaces.
1.3.6.1.2.1.2
Hope that helps.
e s Sat, 11/15/2008 - 05:14
Thank you very much! It definitely helped :)
Emanuele
