Pulling a CDR report on a number called (CCM 3.3)
Nov 14th, 2008
I need to pull a CDR report on a number taht keeps getting calls from here but do not know how has been placing them. I'm in the CDR Analysis and Reporting. I've looked around, but which one is the one that I want to use?
Thanks..
arthurbecker Fri, 11/14/2008 - 10:50
I don't know which extension is calling the number. I'm trying to find out which extension(s) is calling this number as well at what times.
Jaime Valencia Fri, 11/14/2008 - 10:53
  • Cisco Employee,
  • Hall of Fame,
    2011
go to the phone, directories missed/received/placed calls
java
if this helps, please rate
arthurbecker Fri, 11/14/2008 - 11:00
I'm looking at over 200 phones and the span is for over a month. i cannot physically do this. That is why I'm looking to run the CDR report in the 1st place.
bsieber39 Fri, 11/14/2008 - 11:45
use SQL inside the server that is storing your CDR records:
here is a sample--it works for call manager 4 and up so not sure about 3 but maybe:
DECLARE @StartDateTime DATETIME
,@EndDateTime DATETIME
SELECT @StartDateTime = '03/11/2008 08:00'
SELECT @EndDateTime = '03/11/2008 18:00'
select callingPartyNumber,originalCalledPartyNumber,finalCalledPartyNumber,globalCallID_callId,
duration,origCalledPartyRedirectReason,lastRedirectRedirectReason,
datetimeorigination = DATEADD(hour,-4,(dateadd(second ,dateTimeOrigination, '1/1/1970')))
,datetimedisconnect = DATEADD(hour,-4,(dateadd(second ,dateTimedisconnect, '1/1/1970')))
from calldetailrecord
where originalCalledPartyNumber = ('XXXX')
AND DATEADD(hour,-4,(dateadd(second ,dateTimeOrigination, '1/1/1970'))) >= @StartDateTime
AND DATEADD(hour,-4,(dateadd(second ,dateTimeOrigination, '1/1/1970'))) <= @EndDateTime
