Help!!! Forward Calls based on Calling Party number????
Answered Question
Nov 14th, 2008
Hello everybody,
I have a great doubt about an issue I was required to do for. That is, is it possible to redirect a call based on the Calling Party Number (or better on a given pattern applied on the calling party number) in Call Manager Express? And what about Call Manager 6.x or 7.0?
I have to give an answer but I dont really know if it is possible.
Need your help please. Thanks in advance.
Correct Answer by Brandon Buffin about 8 years 6 months ago
Yes, this is possible with CME and with CUCM 6/7 if you are using an H.323 gateway. It is not possible when using MGCP.
Hope this helps.
Brandon
Overall Rating: 4.5 (2 ratings)
Correct Answer
Brandon Buffin Fri, 11/14/2008 - 10:49
  • Purple, 4500 points or more
Hope this helps.
Brandon
