Answered Question
Hi !
I would like to know if AAA server solution from Cisco support multi-factor authentification ? something I know and something I own for exemple ??
I did not find anything about this in product documentation on the web ?
Thanks a lot !
Correct Answer by Daniel Laden about 7 years 11 months ago
check out this link
Token Server User Databases
The multi-factor component would be done by a non-ACS server, ACS would relay the authentication request to this device.
Overall Rating: 4.5 (2 ratings)
Richard Burts Fri, 11/14/2008 - 14:13
While the ACS server does not directly support RSA token authentication we have used RSA token authentication with ACS by configuring AAA on routers and switches using TACACS (or Radius) to communicate with ACS and having ACS configure RSA as an external authenticator.
Is that the kind of thing that you are looking for?
