ASK THE EXPERT - CISCO CABLE MODEM TERMINATION SYSTEM (CMTS)
Nov 14th, 2008
  • Gold, 750 points or more
Welcome to the Cisco Networking Professionals Ask the Expert conversation. This is an opportunity to get an update on how to configure and troubleshoot broadband cable on CMTS family uBR10k, uBR72xxVXR and uBR711x with Cisco expert Tejal Patel. Tejal is a customer support engineer at the Technical Assistance Center (TAC) at Cisco Systems, Inc. He joined Cisco in July 1999. His current responsibilities include troubleshooting complex issues, training, and authoring documentation. His areas of expertise are Telco signaling, configuration and troubleshooting of access servers, AAA etc. Tejal is CCIE # 6619 for ISP Dial. He continually shares his expertise by speaking at the Access Design Clinic at Networkers to discuss and resolve the design related technical issues. Tejal holds a bachelor degree in electronics and telecommunication engineering from Poona University, India. Prior to joining Cisco, Tejal was a test engineer at Leemah Datacom Inc. where he was responsible for functional testing of network access server and RADIUS server.
Remember to use the rating system to let Tejal know if you have received an adequate response.
Tejal might not be able to answer each question due to the volume expected during this event. Our moderators will post many of the unanswered questions in other discussion forums shortly after the event. This event lasts through November 21, 2008. Visit this forum often to view responses to your questions and the questions of other community members.
Overall Rating: 4 (2 ratings)
aghaznavi Mon, 11/17/2008 - 09:26
  • Silver, 250 points or more
What are the major differences between DOCSIS 1.0 and DOCSIS 1.1?
tepatel Mon, 11/17/2008 - 10:25
  • Cisco Employee,
The major difference between DOCSIS 1.0 and DOCSIS 1.1 is that DOCSIS 1.0 uses Service ID (SID) to identify cable modems and the devices behind them, while DOCSIS 1.1 uses service flows. DOCSIS 1.1 also has improved MAC framing features, improved provisioning, and authorization with advanced Baseline Privacy Interface Plus (BPI+ ) features.
Service flows are the fundamental units in DOCSIS 1.1 for QoS provisioning. DOCSIS 1.1 allows multiple service flows per cable modem. This means that different types of traffic, such as data, voice, and video, can be separately identified on the same cable modem. This separate identity provides specialized QoS treatment as per traffic needs.
kelash.kumar Tue, 11/18/2008 - 06:33
%C10KEVENTMGR-1-IRONBUS_SUCCESS
I found this error from ubr10k-1, first I tried Csico documents but i didn't find appropriate information usually this error show in CMTS daily two times. what is this error and what is solution?
Kelas kumar
tepatel Tue, 11/18/2008 - 08:39
  • Cisco Employee,
Kelesh,
Pl. post the complete error message here with the ios version that you have on ubr10k. There are many instances via IRONBUS issues can occur. So once i have the complete message, i will be able to comment further.
kelash.kumar Tue, 11/18/2008 - 08:48
hi
software:IOS (tm) 10000 Software (UBR10K2-K8P6U2-M), Version 12.3(21a)BC6, RELEASE SOFTWARE (fc1)
MOdel cisco uBR10000 (PRE2-RP)
Error
%C10KEVENTMGR-1-IRONBUS_FAULT: Ironbus Event 5/0, Restarting Ironbus
%C10KEVENTMGR-1-IRONBUS_SUCCESS: Ironbus Event 5/0, Restart Successful
tepatel Wed, 11/19/2008 - 10:02
  • Cisco Employee,
We have seen this issue and there is a DDTS CSCsr74034 opened for the same. That issue has been reported on MC5x20H card. Here are the workarounds for a fix for this issue until we have IOS fix.
There are two workarounds for ironbus link status
1. Use Active PRE2 in slot B
2. Do not use a MC520H in slot 5/0
Note : This is not a hardare problem with the card so please do not request for RMA for any equipment due to the ironbus error.
kelash.kumar Tue, 11/18/2008 - 08:49
hi
Error
  • Cisco Employee,
kelash.kumar Wed, 11/19/2008 - 10:15
HI
I have already forwarded software version so can I change? if yes so what's latest software version.
Kelash kuamr
tepatel Thu, 11/20/2008 - 11:45
  • Cisco Employee,
That DDTS has not been resolved yet. So we have to live with those healthy workarounds at the moment. You can monitor that bug and, once its resolved, you can download the ios version which has a fix.
kelash.kumar Tue, 11/18/2008 - 08:52
i
Error
  • Cisco Employee,
kelash.kumar Wed, 11/19/2008 - 10:56
hi
customer impacting with the way it is?
Kelash kuamr
tepatel Thu, 11/20/2008 - 11:47
  • Cisco Employee,
With the workaround in place, there should not be any impact on cable customers.
kelash.kumar Thu, 11/20/2008 - 12:21
hi
can we leave the error as it is? if may possible to damage the line card or CMTS just we need feedback.
kelash kumar
tepatel Thu, 11/20/2008 - 16:29
  • Cisco Employee,
This error will not damage the linecard at all and if you use the workaround mentioned, you will not see that error at all.
tpbcxcsco Fri, 11/21/2008 - 10:12
Hi Tejal, is there a solution to load-balance between the two uplink Gig Eth in the CMTS? We're running OSPF in the cmts and no bgp. Thx
tepatel Fri, 11/21/2008 - 12:59
  • Cisco Employee,
OSPF will allow you to load balance between two equal cost links so use that as a plan.
tpbcxcsco Fri, 11/21/2008 - 11:04
Hi, is the cmts enabled "cef" by default? how do i check it and should I turn "cef" on globally in order to implement the two uplink gig eth load-balancing? thx.
tepatel Fri, 11/21/2008 - 12:06
  • Cisco Employee,
Cef is enabled on CMTS by default and to check it , you need to issue "show ip cef" command.
