trunk between switches
Answered Question
Nov 14th, 2008
hi every body!
i just want to confirm the following:
sw1(config-if)#switchport
#switchport mode dynamic desirable
sw2(config-if)#switchport
# switchport mode dynamic desirable.
Will the trunk form? or do we need to use the command: switchport trunk encapsulation negotiate on both switches?
thanks a lot!
Correct Answer by ropethic about 8 years 2 months ago
Switch A - Switch b
auto - on or desirable
desirable - on, desirable, auto
nonegotiate - on
Correct Answer by Edison Ortiz about 8 years 2 months ago
switchport trunk encapsulation negotiate is the default setting on a switchport, thus there isn't a need to enter such command.
A switchport will form a trunk under the following modes.
Desirable<->Desirable
Desirable<->Auto
on<->on
Please refer to table 12.4 from this URL
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_44_se/configuration/guide/swvlan.html#wp1096213
HTH,
__
Edison.
Correct Answer by lejoe.thomas about 8 years 2 months ago
Sarah,
yes the trunk will form between the two switches.
Lejoe
Overall Rating: 5 (3 ratings)
Correct Answer
lejoe.thomas Fri, 11/14/2008 - 19:55
Sarah,
Lejoe
Correct Answer
Edison Ortiz Fri, 11/14/2008 - 20:03
Desirable<->Auto
on<->on
HTH,
__
Edison.
Correct Answer
ropethic Sat, 11/15/2008 - 06:22
Switch A - Switch b
nonegotiate - on
