IPS IOS UPGRADE 4240
Nov 14th, 2008
ROMMON Variable Settings:
ADDRESS=172.16.X.X ---MANAGEMNET IP
SERVER=172.16.x.x----TFTP SERVER IP
GATEWAY=172.16.X.X -------MANAGEMNET IP
PORT=Management0/0
VLAN=untagged
IMAGE=IPS-K9-6.1-1-E1.pkg
CONFIG=
LINKTIMEOUT=20
PKTTIMEOUT=4
RETRY=20
tftp [email protected] via 172.16.X.X
TFTP failure: Packet verify failed after 20 retries
OBSERVATION:
I am doing the ios upgration from IPS-K9-5.1-6-E1 to IPS-K9-6.1-1-E1.pkg
1. rommon #12>---
once coming rommon mode i am not able to ping 172.16.x.x manage ip.
2.TFTP failure: Packet verify failed after 20 retries
3.all same network only
How to do solve the problem or give me idea
Thanks.
Overall Rating: 4 (1 ratings)
rhoud Mon, 11/17/2008 - 08:02
The problem is your trying to do install a upgrade package from rommon. You can only install system images using this method (IPS-4240-K9-sys-1.1-a-6.1-1-E2.img. To upgrade you need to reboot the sensor and let it come back up then issue:
(conf)#upgrade ftp://@X.X.X.X///IPS-K9-6.1-1-E1.pkg. By upgrading you will save all your config changes and sig tunings. Where as a system image will bring your sensor back to default configuration with the new image.
Hope this helps,
rhoud
CSCO10320953 Mon, 11/17/2008 - 09:22
Thanks for good info.Customer will give the down time with in week.Once i complete the work and do the rating ...
CSCO10320953 Fri, 11/21/2008 - 17:38
After upgration IPS-4240-K9-sys-1.1-a-5.0-2.img to IPS-4240-K9-sys-1.1-a-6.1-1-E3.img i am getting below message
There is no license key installed on the IPS-4240. The system will continue to operate with the currently installed signature set. A valid license must be obtained in order to apply signature updates. Please go to http://www.cisco.com/go/license
to obtain a new license or install a license. Its not going to promt mode ?
How can i go to ips configuration mode?
Any steps which are to be done first?
