ASDM launch on ASA outside interface
Nov 15th, 2008
I want to launch ASDM on ASA outside interface having private IP from locan LAN. This server farm asa is connected with core switch.From Core switch i can ping the asa outside ip ( In ASA i did the following:
http server enable
http inside
http outside
telnet outside
Please help..
JORGE RODRIGUEZ Sun, 11/16/2008 - 00:01
what subnet are you seating on for the outside? seems as you are comming from the outside as network, if so you you need to add another statement for asdm access via outside interface.
add this and try launching asdm from this subnet to access fw.
asa(config)#http oustide
