VLAN ACL not working -urgent
Answered Question
Nov 15th, 2008
please find the VLAN details given below..
VLAN: teamA-VLAN12, teamB-VLAN11, teamC-VLAN13, teamD-VLAN20, teamE-VLAN21
VLAN11=10.138.74.192/26
VLAN12=10.138.75.0/25
VLAN13=10.138.75.128/26
VLAN17=10.138.77.0/24 (server)
VLAN20=10.138.75.192/27
VLAN21=10.138.75.224/27
ACL for teamA
team A should get access of 10.138.77.9,10.138.77.90-10.138.77.101,10.138.77.47-10.138.77.61 and 10.138.76.0-10.138.76.255
team A should not get access of VLAN11, VLAN13 and VLAN 20.
Please find the ACL comnfiguration which I have done..
access-list 112 permit ip 10.138.75.0 0.0.0.126 host 10.138.77.9
access-list 112 permit ip 10.138.75.0 0.0.0.126 10.138.77.90 0.0.0.11
access-list 112 permit ip 10.138.75.0 0.0.0.126 10.138.77.47 0.0.0.14
access-list 112 permit ip 10.138.75.0 0.0.0.126 10.138.76.0 0.0.0.255
access-list 112 deny ip 10.138.75.0 0.0.0.126 10.138.74.192 0.0.0.62
access-list 112 deny ip 10.138.75.0 0.0.0.126 10.138.75.128 0.0.0.62
access-list 112 deny ip 10.138.75.0 0.0.0.126 10.138.75.192 0.0.0.30
access-list 112 deny ip 10.138.75.0 0.0.0.126 10.138.77.0 0.0.0.255
access-list 112 permit ip any any
interface Vlan12
ip access-group 112 in
** but after applying the above ACL, team A unable to access 10.138.77.90-10.138.77.101 and 10.138.77.47-10.138.77.61 range.some other access also blocked.
please help to resolve this issue.
som
Correct Answer by vaisharm about 8 years 4 months ago
Som,
I have broken down your question into sub-parts below. As Giuseppe had pointed out, this ACL is different from what you have posted.
a) Team A should get access to 10.138.77.9
access-list 112 permit ip 10.138.75.0 0.0.0.127 host 10.138.77.9
!- permits host 10.138.77.9
b) Allow access to 10.138.77.90 - 101
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.90 0.0.0.7
!- permits IP address range 10.138.77.88-95, need to deny 88-89
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.77.103 0.0.0.1
!- denies IP address range 10.138.77.88-89
c) Allow access to 10.138.77.47 - 61
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.47 0.0.0.0
!- permits IP address 10.138.77.47 only
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.48 0.0.0.15
!- permits IP address range 10.138.75.48-63, need to deny 62-63
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.77.63 0.0.0.1
!- denies access to IP address range 10.138.77.62-63
d) Allow access to 10.138.76.0 - 10.138.76.255
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.76.0 0.0.0.255
e) Deny access to VLAN11, VLAN13 and VLAN 20.
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.74.192 0.0.0.63
!- denies VLAN 11
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.75.128 0.0.0.63
!- denies VLAN 13
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.75.192 0.0.0.31
!- denies VLAN 20
f) if you want to deny access to the server then specify the server IP address.
access-list 112 deny ip 10.138.75.0 0.0.0.127 host 10.138.77.x
You had permit ip any any in the end. With this you would enable access to all destinations which you have not denied here. Effectively, the permit statements above would not be required if you use permit ip any any in the end. That line should be dropped.
HTH,
~Vaibhav
Overall Rating: 4.5 (2 ratings)
Giuseppe Larosa Sat, 11/15/2008 - 04:25
  • Hall of Fame,
    Founding Member
Hello Som,
for net 10.138.75.0/25 the wildcard mask is:
01111111 = 127
126 is = 01111110 and odd addresses like 10.138.75.3 doesn't match these lines
the same reasoning applies to some destinations.
90 = 01011010
101 = 01100101
so they have very less in common
the wildcard masks are to be calculated in binary and then converted in decimal
10.138.77.88 0.0.0.7
will match from 10.138.77.88 t0 10.138.77.95
10.138.77.96 0.0.0.7
will match from 10.138.77.96 to 10.138.77.103
modify all lines following the above suggestions
Hope to help
Giuseppe
somnath21 Sun, 11/16/2008 - 21:45
I have following range of VLAN.
For example: I need to give access to VLAN 12 like that...
VLAN12 sould get access of below host or network..
10.138.77.9
10.138.77.47-10.138.77.62
10.138.75.224-10.138.75.255
Access blocked:
VALN11 (10.138.74.192/26)
VLAN13 (10.138.75.28/26)
VLAN20 (10.138.75.192/27)
VLAN17 (10.138.77.0/24) (server)
Configuration..
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.90 0.0.0.15
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.47 0.0.0.15
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.128 0.0.0.127
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.75.224 0.0.0.31
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.77.0 0.0.0.127
Please let me know whether above configuration is ok or not?
Davy Ad Mon, 11/17/2008 - 01:40
Hi Somnath,
I think you should change the second line.
to:
2nd access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.90 0.0.0.11
And what is this doing -> access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.128.0.0.0.127<- i can't understand what/where is this for
DAK
Davy Ad Mon, 11/17/2008 - 01:49
Hi somnath,
You are right only some little correction need to be done. Configure it like this
access-list 112 permit ip 10.138.75.0 0.0.0.127 10.138.77.128 0.0.0.127 -> removed this all let me know what for
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.75.28 0.0.0.63
access-list 112 deny ip 10.138.75.0 0.0.0.127 10.138.77.0 0.0.0.255
Then i think it should be fine
DAK
somnath21 Mon, 11/17/2008 - 01:46
yes ....got it
wildcard mask should be according to block size (2,4,8,16,64).
Thanks!!
Correct Answer
vaisharm Mon, 11/17/2008 - 04:10
  • Cisco Employee,
Som,
!- denies VLAN 11
!- denies VLAN 13
!- denies VLAN 20
HTH,
~Vaibhav
