3750G configuration stack commands
Nov 15th, 2008
Using a current 2950, and replacing with a 3750G POE-with an additional 3950G as a back-up (stack) is there a configuration sheet that will give me a step-by-step CLI so I can configure the new switch with my current 2950 configuration?
Giuseppe Larosa Sat, 11/15/2008 - 10:15
Hello Leroy,
I would first configure the stack of the two new C3750s.
Actually, the ports will be seen as 1/0/x and as 2/0/y after you have the stack running.
After having done this, the configuration of the single port can be copied to the right port(s).
port 0/x on c2950 becomes 1/0/x and 2/0/x on the c3750 stack if you want to have a backup switch.
if the second C3750 is for backup I wonder if the stack is useful.
Hope to help
Giuseppe
CCDEdeity Mon, 11/17/2008 - 06:34
If I the 3750 config works I will let everyone know the details less headaches for everyone else
CCDEdeity Mon, 11/17/2008 - 05:34
Hey Dave,
Thanks for your help-this may get me rolling in the right direction.
Roy
