Help for CUCM Upgrade (From 4.x to 6.1.2)
Nov 15th, 2008
I have a question regarding Cisco Unified Communication Manager 6.1 upgrade, we have customer already order to upgrade from CUCM 4.2.3 to CUCM 6.1.2.
I know about this upgrade that system will check for the current number & type of connected IP Phones already installed with CUCM 4.X then it will provide the license depends on this calculation.
But this has 800 different types of IP Phones & has already purchased 120 IP Phones but it's still in the BOX not distributed yet, he asking if there is a solution to include those 120 phones while doing the upgrade as it's very difficult or actually impossible to move them out from the boxes then plug into PoE switches during the upgrade process then put them back aging inside the boxes.
Or he has to purchase new DLUs for those 120 phones if they are not attached during the installation?
Please advice.
Ahmed Rizk
Sascha Monteiro Sat, 11/15/2008 - 13:02
  • Silver, 250 points or more
just BAT all those 120 phones into the CUCM before you run DMA, they don''t have to be connected, just configured.
Jaime Valencia Sun, 11/16/2008 - 16:30
  • Cisco Employee,
  • Hall of Fame,
    2011
you should have a PAK for those phones, when you register those PAKs you should get the necessary DLUs for each phone model to work
java
if this helps, please rate
