Clearing all historical data from the graphs
Nov 15th, 2008
Hi all,
Now that I have upgraded to 4.1.1c I want to clear all historical data and start from scratch with the graphs/stats/reporting. Is there a way to do such a thing? Could not find anything in the docs other than "clear statistics all" which seems unrelated.
Adrian
adrianjames Sat, 11/15/2008 - 16:41
Sorry I found this is another post by Dan:
Go into System, Configuration, System Properties. Change System.monitoring.recordLimitDays to 0 and then change it back to the # of days you have set in your system (I usually just leave set to default). That should clear your stats.
I tried it and it works.
Adrian
ropethic Mon, 11/17/2008 - 04:56
  • Silver, 250 points or more
http://www.cisco.com/en/US/docs/app_ntwk_services/waas/waas/v411/configuration/guide/monitor.html#wp1043484
Enclosed is the report montioring and configuring guide.
The clear statistics command clears all statistical counters from the parameters given. Use this command to monitor fresh statistical data for some or all features without losing cached objects or configurations.
