ADSL Router with PPTP Client ?
Nov 15th, 2008
Hiya,
Does Cisco has ADSL Router which have build in pptp vpn clients like the Draytek router ?
It is not quite clear on the website whether the 877 for example supports just pptp passthrough or whether it actually has a client build in ...
sadbulali Thu, 11/20/2008 - 07:34
  • Bronze, 100 points or more
Cisco 870 Series of integrated services routers are fixed-configuration routers that support multiple types of DSL technologies, broadband cable, and Metro Ethernet connections in small offices.They also support Point-to-Point Tunneling Protocol (PPTP) passthrough.
Gomjaba08 Thu, 11/20/2008 - 23:48
We have those VPN server mainly for our customer in place. The VPN Server are based on Server 2003 RRAS .. With those VPN server we give customer the option to login to their server via the private interface.
IPSec would simply add to the complexicity... We need to make sure that EVERY customer, no matter what his circumstances are, are able to login .. So PPTP is unfortunately the way to go and cannot be changed any time soon. The Drayteks do a good job but crashing every know and then and we therefore look for a replacement .. but shockingly - there are none :(
remi-reszka Fri, 11/21/2008 - 06:22
It's sad but true. I guess the PPTP is getting a bit out of the market due to its week authentication therefore people go for IPSec best if with RSA authentication but preshare will also do the job. We had PPTP in place with termination on 2003 RRAS but only for employees on travel, all other offices were terminated on IPSec.
IPSec is not that complex as it looks. If you have static IP addresses at each location you just do simple config for IPsec site2site in transport mode and tunnel it with GRE. You could still use PPTP as pass through for those employees on the road. NAT config for IPSec can be a bit of hassle but once you've got a grasp of IPSec it will become fairly easy.
If no static IP addresses you could use EZPVN in NEM, it also works great.
Gomjaba08 Fri, 11/21/2008 - 11:24
That would work for our technical staff .. But it is simply not doable for our customer .. We are talking about 5k different accounts here :)
remi-reszka Fri, 11/21/2008 - 20:55
Oh, that changes the whole picture! I'll take a look once again towards your solution. Will be in touch.
Gomjaba08 Sat, 11/22/2008 - 02:27
Thanks a lot :)
We wouldn't have a problem with the Draytek router, but their firmeware is unstable and their support rubbish ..
Draytek is one of the companies who prefer to add new features rather than making the current ones stable :(
