Question about the NM-HD-2VE module for home lab use
Answered Question
Nov 16th, 2008
I'd like to set up the NM-HD-2VE module with a VIC-2MFT-T1 and VIC-1MFT-T1 cards to use in a Cisco 2610 so that I can set up a PSTN switch for my home lab (this 2610 will also be used as a gatekeeper). I've only just started looking at the NM-HD-2VE and would like to know if I need to purchase PVDM for its slots in order for it to function. Any insight is appreciated.
Shikamaru
Correct Answer by Rob Huffman about 8 years 4 months ago
Hi Shikamaru,
My understanding is that the NM-HD-2VE has built-in DSP resources (3 DSP) and does not require the purchase of additional PVDM's
http://www.cisco.com/en/US/docs/ios/voice/cminterop/configuration/guide/vc_enh_confr_vgr.pdf
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Mon, 11/17/2008 - 06:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Shikamaru,
Hope this helps!
Rob
shikamarunara Mon, 11/17/2008 - 06:44
Thanks, Rob. Yes, apparently there are 3 16-channel DPSs embeded, so for lab purposes it should suffice.
-Shikamaruna
Rob Huffman Mon, 11/17/2008 - 06:49
  • Hall of Fame,
    Founding Member
Hi Shikamaruna,
Good stuff my friend! Best of luck with your studies.
Cheers!
Rob
