ASA Phone Proxy
I'm trying to setup this feature on ASA 5505 and phone can successfully download a configuration file, but it can't register to CUCM server.
I can see the following message from debug inspection tls-proxy:
TLSP d5087d20: Using trust point '_internal_myctl_SAST_0' with the Client, RT proxy d5491f90
TLSP d5087d20: Waiting for SSL handshake from Client outside:
TLSP d5087d20: --> Proxy Rx 52 bytes
TLSP d5087d20: <== Proxy Tx 7 bytes
TLSP d5087d20: new event: KILL_FLOW
TLSP d5087d20: Tear down proxy for Client outside:
TLSP d5087d20: Tear down proxy for Server inside:
Config attached.
gogasca Sun, 11/16/2008 - 23:55
Under CUCM server is the CUCM with an IP address or using name and DNS suffix configured?
Is the Cisco UCM Cluster secure or non-secure?
what is the message displayed in the IP Phone when attempting to register?
What is the message for Phone status messages?
Which Phone model?
ezerangue Fri, 11/21/2008 - 08:59
I see the 192.168 is outside, and 172.22 is inside? You show the callmanager ip's to be
record-entry cucm-tftp trustpoint tftp_server address
record-entry cucm trustpoint sec_cucm address
record-entry cucm trustpoint pri_cucm address
Are these the actual ip address of Callmanager?
