From outside to inside access ( number of static map)
Answered Question
Nov 16th, 2008
HI
I have two office A and B. A is head office where have 200 user and in B offcie has 300 user.
From A to B connect sceniro:
Boffice-Router-outsideFWinside-A office.
my Goal is all user From office B can access all PC in office A. As office A in behind ASA then I need 200 static Map.
As usual we do point to point static map.
its eassy for some of server or user pc.
As in my sceniro a lot of number pc access so its difficult configure 200 static map. so have any other way ?
Regrads
Biplob
Correct Answer by Mo'ath Al Rawashdeh about 8 years 2 months ago
on the firewall, please send me the output of "show logging | inc x"
where x is the IP address you are pinging from.
Overall Rating: 4.5 (2 ratings)
Mo'ath Al Rawashdeh Mon, 11/17/2008 - 01:23
Is there an ISP link between the two offices?
If yes, is there a VPN tunnel established between the two offices?
If yes, you may use NAT zero.
biplobkhan Mon, 11/17/2008 - 03:10
Thanks.
No ISP Link. Two office are connected via VSAT. no VPN tunnel between two office.
at present 5 sever are static map. but decession now that all pc of Office A are available for office B but its come throw firewall. so I need more 195 static map ?
thanks
Biplob
Mo'ath Al Rawashdeh Mon, 11/17/2008 - 03:26
not really. Use NAT zero and thats it.
But you have to modify your ACLs on the firewall as well to allow the traffic between the 2 offices.
Cheers.
biplobkhan Mon, 11/17/2008 - 22:38
I am confused. pls clear.
At present scenerio example:
pix outside IP: 192.168.10.1
pix inside IP : 192.168.40.10
ACL 101 permit tcp any any
ACL 101 permit Icmp any any
static( ouside, inside) 192.168.10.11 192.168.40.11 0 0
access-group 101 in interface outside.
**As from my office user not connect internet so nat configure in here.
As your suggation if I configure
nat (inside) 0 192.168.40.0 255.255.255.0
then i do not need any static map ????
office B ( 172.16.20.X) can access Office A (192.168.40.X) without any mapping ???.
and can ping direct 192.168.40.X ?
----can you give me a sample configure---
regrads
Biplob
Mo'ath Al Rawashdeh Tue, 11/18/2008 - 00:40
Hi Biplob,
yes, but don't use:
since you still need traffic going from office A to the internet to be NATed.
So use an ACL like below:
access-list inside-to-outside-NAT-EXCLUDE line 1 extended permit ip 192.168.40.0 255.255.255.0 172.16.20.0 255.255.255.0
nat (inside) 0 access-list inside-to-outside-NAT-EXCLUDE
The config above allows users in office A to connect to office B. For office B users to connect to office A users, use the config below:
access-list outside-to-inside-NAT-EXCLUDE line 1 extended permit ip 172.16.20.0 255.255.255.0 192.168.40.0 255.255.255.0
nat (outside) 0 access-list outside-to-inside-NAT-EXCLUDE.
* Please use the rating system once your problem is solved.
Moath.
biplobkhan Tue, 11/18/2008 - 01:15
If I understand then according to your summary:
office B(172.16.20.0)-FW-OfficeA(192.168.40.0)
Only B office user access to office A then:
B office user access to office A and also users of office A connect to Internet then:
beside this i do not need any other config/
regrads
Biplob
Mo'ath Al Rawashdeh Tue, 11/18/2008 - 01:27
hi,
From office A to office B:
From office B to A:
Please configure all above to allow traffic from both offices.
"beside this i do not need any other config"
Please make sure that the traffic ACLs applied on the outside interface and inside interface (if any) allow the traffic between the 2 offices.
biplobkhan Tue, 11/18/2008 - 01:42
too much thanks. Now I am clear 90 %. now a little bit confution.
1. your last line tell --Please make sure that the traffic ACLs applied on the outside interface and inside interface --- by this line which you meaning ,--it is regrading access group applied interface ?
i don not need any access -group ?
2. you mention example
office B to office A:
and Both.
but If I need additional that
office B to office A and office A connect to Internet. that means office A users also connect to internet then time what I do.
pls give me an example aditionaly. becuse I am worried that if I give no nat exclude 192.168.40.0 then no user of office A can not connect internet.
sorry for your time kill.
regrads
Biplob
Mo'ath Al Rawashdeh Tue, 11/18/2008 - 01:51
1- traffic from outside to inside is denied by default, so you have to allow it in the acl applied on the outside interface.
2- The reason why we used an ACL in the NAT zero statement was to exclude only traffic between the 2 offices from getting NATed.
But there should be another NAT statement for traffic from office A in order to allow it internet access.
If you are confused, plz attach the firewall config to help you more.
biplobkhan Tue, 11/18/2008 - 02:44
result is 0 . i send you the configation what i do. pls wait 5 min.
Mo'ath Al Rawashdeh Tue, 11/18/2008 - 03:29
Show running access-group, then modify the ACL applied on the outside interface to allow office's B range to connect to office's A range.
biplobkhan Tue, 11/18/2008 - 04:11
I do additionaly
access-list 102 permit icmp any any
access-list 102 permit Ip any any
access-group 102 in interface outside
then also configure
access-list 101 permit ip 192.168.16.0 255.255.255.0 192.168.40.0 255.255.255.0
nat (outside) 0 access-list 101 [this line give warning]
regrads
Biplob
Correct Answer
Mo'ath Al Rawashdeh Tue, 11/18/2008 - 04:44
Mo'ath Al Rawashdeh Tue, 11/18/2008 - 05:59
Please remove the settings you applied and try these:
Cheers
biplobkhan Tue, 11/18/2008 - 23:17
Its a good news that your last pescription is right and I reach my destination goal and confused zero. before this test I know that out side user can access inside only by static map.
Too much thanks and warm regards to you for co-operation the test.
Be well and next time see you again.
regrads
Biplob
