2 ISP nat problem
Nov 17th, 2008
Good day .
Our topology is :
----1841----ISP1
ASA5510---
----1841----ISP2
We use EIGRP for routes redistribution.
Both 1841 has static nat rules for our inside services. When outside client is trying to connect to one of the translated outside ip adresses(for example the first one) he may recieve incoming packets from the other adress (second). So is there a way to restrict outgoing nat sessions to the route it was originated from.
Please excuse my english. Any feedback will be greatly appretiated.
mtebaccount Mon, 11/17/2008 - 00:46
hmm , dont think its exactly our case . Basicly we have 2 different outside adress pools , translation from each of them leads to one inside host , but it seems that ASA routes all outgoing nat translations only over one pool .
__________________--1841(nat 1.1.1.1)
10.10.10.1 --ASA--
__________________--1841(nat 2.2.2.2)
So basicly , client is connecting to 1.1.1.1 , and everything works fine , his session is translated to 10.10.10.1.
But when he is trying to connect to 2.2.2.2 , the session is returned to him over 1.1.1.1.
Probably something is wrong with eigrp redistribution . If this is the overlapping network case , then please excuse my poor knowledge .
Mohamed Sobair Mon, 11/17/2008 - 02:00
No this is not Overlapping Network, and please execuse my poor understanding.
Probably its a routing issue.
Mohamed
mtebaccount Mon, 11/17/2008 - 02:12
Seems like routing to me as well . Is there a way to configure asa route incoming sessions back to the router they were orginated from (topology with 2 ISP)?
sdoremus33 Mon, 11/17/2008 - 10:37
Please provide the config for the 1841, and the ASA. Thanks
One option is to deploy split tunneling which might allieviate your problem, but first need to look at the config.Thanks
