Input errora at the int
Nov 17th, 2008
I don't understand where to dig.
I have increased numbers of input errors and same numbers of ignored. Is it problem with cable or another problem?
At the other side of cable ( ASA 5510) there are no errors.
416 input errors, 416 ignored
#sh int f4/1
FastEthernet4/1 is up, line protocol is up
Hardware is i82543 (Livengood), address is 0016.c794.d971 (bia 0016.c794.d971)
Description: ### Int to ASA VPN GATE ###
Internet address is 5.5.5.1/30
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 16/255, rxload 7/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 01:30:29, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:03:52
Queueing strategy: fifo
Output queue: 0/40 (size/max)
30 second input rate 2851000 bits/sec, 1870 packets/sec
30 second output rate 6640000 bits/sec, 1626 packets/sec
458767 packets input, 97163477 bytes
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
416 input errors, 0 CRC, 0 frame, 0 overrun, 416 ignored
0 watchdog
373076 packets output, 154022489 bytes, 0 underruns
0 lost carrier, 0 no carrier
Giuseppe Larosa Mon, 11/17/2008 - 01:03
  • Hall of Fame,
    Founding Member
Hello Mike,
here is the definition of ignored
Shows the number of received packets ignored by the
interface because the interface hardware ran low on internal
buffers. These buffers are different from the system buffers
mentioned previously in the buffer description. Broadcast
storms and bursts of noise can cause the ignored count to be
increased.
you can try to increase the input hold-queue to see if they stop to increment
int f4/1
hold-queue 1024 in
However, they are less then 0.1% so they shouldn't cause performance issues
Hope to help
Giuseppe
rmv72 Mon, 11/17/2008 - 01:49
Hello!
Unfortunatly it didn't help...
Why do you think i need to increase that queue.
From output
Input queue: 0/1024/0/0 (size/max/drops/flushes)
seems 0 drops or i missunderstood it?
#sh int f4/1
reliability 255/255, txload 15/255, rxload 7/255
Last input 02:32:45, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:06:01
Input queue: 0/1024/0/0 (size/max/drops/flushes); Total output drops: 0
30 second input rate 3066000 bits/sec, 1463 packets/sec
30 second output rate 6009000 bits/sec, 1283 packets/sec
482300 packets input, 122238132 bytes
661 input errors, 0 CRC, 0 frame, 0 overrun, 661 ignored
0 watchdog
409856 packets output, 224471677 bytes, 0 underruns
Giuseppe Larosa Mon, 11/17/2008 - 05:08
  • Hall of Fame,
    Founding Member
Hello Mike,
it was a try.
There is a chance this is just noice of some protocol not active/not known on this interface.
Hope to help
Giuseppe
rmv72 Tue, 11/18/2008 - 04:59
I found where was problem.
I have service-policy input XXX at that interface.
Errors disappeared after remove that.
