DBwalker has Invalid Switch ID errors
Nov 17th, 2008
  • Bronze, 100 points or more
We get " switch ID is invalid " errors for about 1000 of these errors for almost all the subscribers in Unity on both the primary and failover servers. What could be causing this issue and how do I fix this ?
Running dbWalker version:4.0.56
Search for '(error)' or '(warning)' to find logged errors and warnings.
Starting walk at:11/15/2008 2:57:07 PM
Local Unity Version=5.0(1.0)
Local server name= MNSVWUNYP002
Backend is Exchange 2000 or 2003
1699:(error) The 'SchemaMajorVersion' value is NULL in the row with 'Alias' value matching the primary server name in the 'Servers' table. This can cause problems if you try to upgrade this system to a newer version of Unity. Please contact TAC.
1700:(error) The 'SchemaMinorVersion' value is NULL in the row with 'Alias' value matching the primary server name in the 'Servers' table. This can cause problems if you try to upgrade this system to a newer version of Unity. Please contact TAC.
Checking LastModifiedTime column for all entries in the Configuration table
*** Starting subscriber walk ***
Alias=ajackson
Display Name=Jackson, Angela
Jump to this subscriber in the SA using this link: Open SA to this subscriber
COS Alias=defaultsubscriber
Location Object Alias=default
Subscriber has no voice name recorded
Location object display name=Default
Subscriber is assigned to language=English (United States)
1199:(error) Subscriber set to switch ID that is not valid: 0
This can be fixed by going to the subscriber profile page in the SA and selecting a valid switch for this user.
Subscriber has no private lists
1183:(error) Notification device:Home Phone has a switch ID that is not valid: 0
You can correct this by going to this notification device for this subscriber in the SA and selecting a valid switch for it
1183:(error) Notification device:Pager has a switch ID that is not valid: 0
1183:(error) Notification device:Pager 2 has a switch ID that is not valid: 0
1183:(error) Notification device:Phone 2 has a switch ID that is not valid: 0
1183:(error) Notification device:Phone 3 has a switch ID that is not valid: 0
1183:(error) Notification device:Phone 4 has a switch ID that is not valid: 0
1183:(error) Notification device:Phone 5 has a switch ID that is not valid: 0
1183:(error) Notification device:Phone 6 has a switch ID that is not valid: 0
1183:(error) Notification device:Spare Phone has a switch ID that is not valid: 0
1183:(error) Notification device:Work Phone has a switch ID that is not valid: 0
1439:(error) MWI device:MWI-1 has a switch ID that is not valid: 0
You can correct this by going to this messages page for this subscriber in the SA and selecting a valid switch for it
Thank you
Ranj
Bradford Magnani Mon, 11/17/2008 - 06:15
  • Cisco Employee,
Ranj,
You're getting these switch ID mismatches because the current integration ID configured in the Integrations Manager differs from what's currently in the database. These need to match.
If you go to Start > Programs > Unity > Manage Integrations and highlight Properties of the switch you're concerned with, you'll see the Integration ID there. You can then go to the Tools>Subscriber-Phone System Associations option and then re-assign the subscribers to the proper phone system, or to another.
Hope this helps,
Brad
lordshawn Thu, 11/20/2008 - 07:52
IT was probably caused by something deleting the itnergration and/or making changes...which changes the switch ID incrementaly. Or someone could of BUlk Edited the Switch id...
