Phone not declared in cdr
Nov 17th, 2008
Hi all;
i've a CCM 4.1 with a MEIPS installed for taxation, all work fine except a 7970 phone which is not declared in the cdr statistics instead of making and receiving calls,
any idea will be appreciate
Med
jbayuka Fri, 11/21/2008 - 14:37
  • Bronze, 100 points or more
Are you just looking in the table in SQL? If you try to bring up the records via the webpage, are you getting any errors when you try to pull them up?
