ACCESS LIST
Answered Question
Nov 17th, 2008
Hi. can you please check the access list below?
Cannot telnet to 10.1.1.1 from outside.
What is wrong with the access list below and what should I change on it??
Sorry..I'm a beginner.
appreciate your help.thanks
permit tcp any any established
permit icmp any any
permit icmp any host 10.1.1.1 echo
permit icmp any host 10.1.1.1 echo-reply
permit icmp any host 10.1.1.1 time-exceeded
permit udp any host 10.1.1.1 range 33434 33524
Correct Answer by Jon Marshall about 8 years 8 months ago
Jayson
this is used to allow traffic for already initiated connections to return through the router so
H1 - (fa0/0) R1 (fa0/1) S1
H1 = is a client host
S1 = a server the clients wants to connect to
R1 is a router
you have an acl 101 with "permit tcp any any established" in it and this acl is applied inbound on R1's fa0/1 interface ie.
int fa0/1
ip access-group 101 in
If H1 telnets to S1 the initial packet gets to S1 via R1. The acl has no effect at this time because the traffic is outbound on fa0/1 towards S1.
When S1 responds the "permit tcp any any established" line allows the return traffic back in.
But if S1 started the telnet conversation to H1 the router would deny the packet because the connection was not started by H1.
It is important to note that using the eastablished keyword means the router is only really checking for a TCP flag in the packet header and as such it is very easy to fool and should in no way be viewed as a firewall function. I don't want to overload you with TCP flags/stateful connections but if you need more info let me know.
The permit icmp lines in order
1) allow any address to send a ping request to 10.1.1.1
2) allow any address to send a ping response to 10.1.1.1
3) all any host to send a "time-exceeded" response to 10.1.1.1
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 11/17/2008 - 04:20
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jayson
Could you provide a bit more detail
1) where is the access-list applied (on which interface ) and in which direction.
So when you say you cannot telnet from outside to 10.1.1.1 is 10.1.1.1 on the inside ?
If so and this acl is applied on the outside interface in an inbound direction then you will not be able to. You would need a line like
permit tcp any host 10.1.1.1 eq 23
Jon
jsheriony Mon, 11/17/2008 - 04:33
hi Jon,
10.1.1.1 is the interface inside.
cannot go inside from the outside...
will "permit tcp any host 10.1.1.1 eq 23"
be enough???
ANd if not so much trouble,can you please tell
me the lines below are for?
I thought the first line could be enough to
permit telnet...
Thanks a lot for the attention
Correct Answer
Jon Marshall Mon, 11/17/2008 - 04:46
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jayson
R1 is a router
int fa0/1
Jon
jsheriony Mon, 11/17/2008 - 04:50
Jon,
very very helpful.
thanks a lot...
now i understand very well
Jayson
Jon Marshall Mon, 11/17/2008 - 04:56
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jayson
No problem, glad to have helped and thanks for the rating.
Jon
jsheriony Mon, 11/17/2008 - 04:58
Jon,
by the way, the line below whouls resolve the
whole issue, right???
Thanks again
Jon Marshall Mon, 11/17/2008 - 05:00
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Yes it would providing the acl is applied inbound on the outside interface.
Jon
