11-17-2008 04:29 AM - edited 03-06-2019 02:31 AM
Please Help me choose IOS with SSH v2 for 2621 and 7206 routes
thanks and regards
Jagdev
Solved! Go to Solution.
11-17-2008 04:38 AM
Jagdev
It's not as simple as just naming an IOS because a lot depends on what else you need your routers to run. You need to use Cisco's Feature Navigator to determine which IOS will support SSH and also all the other features you need. You will need an IOS that supports 3DES for SSH. Give it a go, it's a very useful tool to become familiar with, and if you still have problems then come back -
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Jon
11-17-2008 04:38 AM
Jagdev
Jon
