ACE class-map match operation
Nov 17th, 2008
Below the base configuration which worked properly. The stressed tcp port connections were forwarded to server B while
any other connections were forwarded to server A by ACE.
rserver A
rserver B
Serverfarm A
rserver A
Serverfarm B
rserver B
class-map A
2 match virtual-address 1.1.1.1 any
class-map B
2 match virtual-address 1.1.1.1 tcp eq 80
3 match virtual-address 1.1.1.1 tcp eq 81
4 match virtual-address 1.1.1.1 tcp eq 82
5 match virtual-address 1.1.1.1 tcp eq 83
6 match virtual-address 1.1.1.1 tcp eq 84
16 match virtual-address 1.1.1.1 tcp eq 94
policy-map load-balance A
serverfarm A
policy-map load-balance B
serverfarm B
policy-map multi-match
class B
load-balance policy B
class A
load-balance policy A
After below modification the tcp port 101 connections were forwarded to server A although
it must be forwarded to Server B.
class-map B
17 match virtual-address 1.1.1.1 tcp eq 100
18 match virtual-address 1.1.1.1 tcp eq 101
I had to clear the multi-match policy and rebuild again for correct operation.
Because we will have to do same configurations ( expanding the class-map B with TCP ports ) in the config on the future i would like to know what would be happened in the ACE.
Thank in advance!
KAROLY KOHEGYI Mon, 11/17/2008 - 08:06
Software
loader: Version 12.2[120]
system: Version A2(1.1) [build 3.0(0)A2(1.1) adbuild_00:25:02-2008/06/05_/auto/adbu-rel3/rel_a2_1_1_throttle/REL_3_0_0_A2_1_1]
system image file: [LCP] disk0:c6ace-t1k9-mz.A2_1_1.bin
installed license: no feature license is installed
KAROLY KOHEGYI Mon, 11/24/2008 - 06:15
the above mentioned situation apeared again.
now the rebuild does not help.
the class map
class-map match-any SZERBSMS
2 match virtual-address 10.42.4.1 tcp eq 5700
3 match virtual-address 10.42.4.1 tcp eq 5660
policy-map type loadbalance first-match SZERB-SMS
class class-default
serverfarm SZERBSMS
rserver host SZERBSMS
ip address 192.168.40.97
inservice
show conn output
Lajos-ACE/Admin# show conn | i 5660
2695 1 in TCP 73 129.3.1.189:1767 10.42.4.1:5660 ESTAB
5460 1 out TCP 91 192.168.40.97:5660 129.3.1.189:1767 ESTAB
Lajos-ACE/Admin# show conn | i 5700
3003 2 in TCP 73 129.3.1.189:1768 10.42.4.1:5700 ESTAB
1901 2 out TCP 94 192.168.40.185:5700 129.3.1.189:1768 ESTAB
there is not any other rule which uses the tcp 5700 port and no other VIP setting for 10.42.4.1 and any.
in spite of above every incoming connections to tcp 5700 are forwarded by ACE to wrong rserver.
very urgent!
