VPN L2L phase 2 problem
Nov 17th, 2008
Please what can be the reason of this error message:
%PIX|ASA-3-713119: PHASE 1 COMPLETED
%PIX|ASA-5-713050: Connection terminated for peer IP_address. Reason: termination reason Remote Proxy IP_address, Local Proxy IP_address
This message indicates the termination of an IPSec tunnel.
%PIX|ASA-7-713900:Descriptive_event_string.
%PIX|ASA-3-713902 descriptive_event_string
Best regards,
Jon Marshall Mon, 11/17/2008 - 07:44
Omar
It sounds like you may have a mismatch in your crypto access-lists. Could you possibly post the relevant bits of information from each device.
If not check that your crypto-map access-list on each device is a mirror image eg.
If you had this on the Pix
access-list vpntraffic permit ip 192.168.5.0 255.255.255.0 172.16.5.0 255.255.255.0
then on the ASA you would need
access-list vpntraffic permit ip 172.16.5.0 255.255.255.0 192.168.5.0 255.255.255.0
Jon
