billing systems CCM
Answered Question
Nov 17th, 2008
What is the billing system for CCM7.
Correct Answer by Rob Huffman about 8 years 3 months ago
Hey Slava,
Hope all is well!
The Cisco Partner program has a number of tested solutions for Billing/Accounting (CDR) products. Here is the link;
http://forums.cisco.com/eforum/servlet/IPCApps?page=Call_Acct_Billing
Hope this helps!
Rob
Correct Answer by dconstantino about 8 years 3 months ago
ISI Infortel solution is the one I use the most it is solid and they have been a long time partner with Cisco.
Overall Rating: 5 (2 ratings)
Jaime Valencia Mon, 11/17/2008 - 10:29
if you mean if we include a billing system with CCM we don't. we only provide CAR with the limited functionality it has.
you're free to look into the partner locator for billing systems compatible with your version since you do not mention what you have
java
if this helps, please rate
Correct Answer
dconstantino Thu, 11/20/2008 - 06:47
