11-17-2008 08:49 AM
I have about 20 groups in a failed concentrator that I need to recover the group password for. This is from the concentrator and the passwords are in hex. I do not have access to the clients which I can decode. Anybody know tips on decoding the cli group passwords in a 3030?
11-17-2008 09:55 AM
I hope the below information helps.
Under Administration-->Access Rights -->Access Settings
Config File Encryption : check NONE , Then Apply.
The file can be viewed from following Tab
Administration ---> File Management
You will the config file and config backup file. There is very "view" button that you can click to view the file now.
** Snapshot from the Lab VPN3000 ***
[group 3]
name=Netpro
password=netpro
Arul
** Please rate if it helps **
11-17-2008 11:38 AM
That was it, thanks I knew there was a way to do that.
R
11-17-2008 08:58 PM
Richards,
Glad to help. Can you also mark the post has solved, so other Netpro members can look up "solved posts" for quick answers.
Arul
11-20-2008 10:15 AM
Arul,
I have tried similar steps for my VPN 3000 but it didn't worked out. Do you have any clue on this ..
Shiva
03-11-2009 02:43 PM
Does this work on a VPN 3000? I am in a similar situation.
Jake
