Corrupt VLANs
Nov 17th, 2008
Hi all. Have been having some one way audio lately...hard to track down. Anyways, I set up a free software package called "OrkAudio" that records the conversations from the phones on the network (for Police and Fire). When I set up the required VLANs, I got a warning about "this is the old way to do it, it may corrupt the VLAN database, there is a new way to do it, etc etc". I am wondering if I have some corrupt VLAN stuff somewhere and that is causing one way audio every so often. How would I tell if the VLAN dbs are corrupt? What is the new way to do it? And OrkAudio requires one port on a server to be set in promiscuous mode...I don't think that would hurt anything, but what does everyone else think (by HURT, I mean weirdly redirect Cisco traffic).
Thanks for any insights at all!
Jon Marshall Mon, 11/17/2008 - 09:49
Doug
The message about the old versus the new way is pretty standard and i have never known using the old way to be the cause of vlan corruption.
If you run "sh vlan" and everything looks okay then i suspect it is.
I suspect if it is intermittent you need to look at
1) Firewalls in the path
2) your routing setup - make sure your routing is stable
3) Link utilisation - are any links in the path fully utilised
4) interface drops on devices along the path
You may also want to consider cross-posting this into one of the "Unified Communications and Video" forums as after a quick search this sort of thing gets asked in those forums most frequently.
Jon
