How to make a MTP as registered with CUCM 6.0?
Answered Question
Nov 17th, 2008
I have 1 Pubs(A) and 1 subscriber (B)
So I have two software MTP.
It shows Software MTP for A is unregistered.
and Software MTP for B is registered.
So how to make it registred the Software MTP with A?
Correct Answer by allan.thomas about 8 years 7 months ago
Verify that the Media Streaming service is activated and running on the Pub.
Hope this helps
Allan.
Pls rate helpful posts.
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 11/17/2008 - 10:34
  • Cisco Employee,
  • Hall of Fame,
    2011
try resetting the MTP, if no avail reset the IPVMS service
java
if this helps, please rate
Correct Answer
allan.thomas Mon, 11/17/2008 - 10:34
  • Blue, 1500 points or more
Hope this helps
Allan.
Pandiyan.d Tue, 11/18/2008 - 02:29
I had restarted the Voice Media Streaming services at CUCM. And the problem has been restarted.
