Phone Registration
Nov 17th, 2008
I have a callmanager business edition version 6.1(2). After all the necessary
configuration including license activation and services activation, the phones could not register with the callmanager. I checked the network configuration on the phones; and they have gotten IP address from the dhcp which I configured on the Voice gateway. They also have the ip address of the
callmanager and the voice gateway as their TFTP server and default router respectively.
I could ping the phones from both the router and the switch and I could also ping the router and the switch from the callmanager. But I could not ping the phones from the callmanager.When I checked the version of the callmanager license from the license unit report, I noticed that it is 6.0 while the Callmanger (business Edition)version is 6.1(2). Could this be the reason why the phones cannot register. I need help.
I think you should make sure you can ping the phones from the CallManager, there could be a routing issue. Are the CCM and the Phones in different subnets?
I also believe there are 3 kinds of licenses that you would need, the Node licenses, the DLUs and the software version license. You should have the software license from the PAK when you bought the upgrade.
joel
angelique.devos Mon, 11/17/2008 - 10:45
Do you have something in your status messages of your phone? Are there any messages on the screen of the phone? Have you tested only one type of phone or multiple types?
You could also check in your RTMT for errors/logs
christianojum Mon, 11/17/2008 - 11:53
Hi Angelique,
There is no error message on the phone. I only notice the phone at intervals display: defaulting to TFTP.
I have tested 7965 and 7940. How do I check the RTMT for errors/logs ?
Joel, The installation is a fresh one not upgrade. I'm only saying that the CM version is 6.1 while the CM license is 6.0. you can see the CM license version from the license unit report on the CM Admin Page.
christianojum Mon, 11/17/2008 - 11:02
Joel,
thanks for your quick response. The phone and the CM are actually on different subnet but i don't think it is the issue because I can ping the two subinterfaces belonging to the different subnets on the router from the callmanager. I can also ping the two vlans belonging to the different subnets on the switch from the call manager.
As for the licenses I loaded three licencses:
1)Cisco unified cm 6.X PAK, 2) 5 seat ccx ENH ccm bundle-AVAILABLE ONLY WITH CCM and 3) the device licences
