%C6K_PLATFORM-1-DISABLE_NON_C7600_CHASSIS
Nov 17th, 2008
Dear Sir,
chassis is OSR-7609 with sup720, OSM-2+4GE-WAN+ and WS-X6548-RJ-45, we will add on SIP-400 with SPA-5X1GE-V2 into slot.
in order to support new hardware.
we try to upgrade from version s72033-advipservicesk9_wan-mz.122-18.SXF13.bin to c7600s72033-advipservicesk9-mz.122-33.SRB4.bin.
when reload new version, message as belows appear. system could not boot.
*Nov 17 18:12:14.355: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Nov 17 18:12:14.279: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
*Nov 17 18:12:14.319: %C6K_PLATFORM-1-DISABLE_NON_C7600_CHASSIS: Software has detected an attempt to run a c7600 image on an incompatible chassis OSR-7609 (36867). This image will not boot.
*Nov 17 18:12:14.739: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Nov 17 18:12:14.739: %SYS-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Nov 17 18:12:14.739: %PFREDUN-4-SUP_FORCE_TO_ROMMON: Supervisor forced to rommon with reason: Cannot continue... disabling autoboot and resetting
System Bo otstrap, Version 8.1(3)
Copyright (c) 19 94-20 04 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
rommon 1 >
due to the new version will check chassis type.
the original type is OSR-7609, please advise how to fix this issue in order to support SIP400 with SPA-5X1GE-V2 on OSR-7609.
looking forward to hearing from you soon.
thank you very much.
best regards,
Jason Lin
