CSA 6.0 will not install. Crashes on Patch Information.
ddevecka
I have tried to install CSA 6.0 a few times and it crashes on "Unable to load patch information into database. setup will now abort". can anyone tell me why this keeps happening. I have installed 5.2 just fine but I want to use 6.
sadbulali
Level 4
Level 4
If you encounter problems with installing or uninstalling the CSA, perform the following tasks:
• Verify that you rebooted the server.
• Verify that the Cisco Security Agent service is not disabled and that its Startup Type value is
Automatic.
• Obtain the installation logs from :\Program Files\Cisco\CSAgent\log. Review the
Cisco Security AgentInstallInfo.txt and driver_install.log files.
• For installations, verify that you installed the Network Shim. The driver_install.log file should state
that csanet2k.inf installed. If the Network Shim is not installed, uninstall the Agent and then install
the Agent again.
• Verify that you did not use Terminal Services.
sadbulali
Level 4
Level 4
Automatic.
the Agent again.
Turns out the server just needed more memory.
