Quick way to find a JTAPI trigger?
Nov 17th, 2008
Is there a quick way to find a JTAPI trigger in all of the Application Configurations?
esa786_2 Mon, 11/17/2008 - 15:46
Hi Arthur. I hope you are using IPCC Express. You can check it in the ipcc exp admin page, subsystem > jtapi> jtapi triggers. where u can find all the triggers configured. is this what u r looking for. if Not pls explain little more what u r looking for. Rout points are pointing to Triggers which again pointing to applications.
regards
esa
arthurbecker Tue, 11/18/2008 - 10:06
I did find the JTAPI number within the JTAPI trigger group. What I'm trying to do is find the Application Configuration that it is associated with under Applications > Application Configuration. The list is too long to go into each one.
esa786_2 Thu, 11/20/2008 - 11:45
Hi Arthur. If you go to the IPCC admin page , subsystem> JTAPI Triggers> you will be seeing all the triggers ( router point #) and in the second colum, you will see the applictiaon names along with the each Triggers#. So you can see all the application name and the triggers name in the same page.
pls let us know whether it is useful.
Esa
