Incompatibility among the authentication WEB-based and Windows Vista
I have a Wireless LAN Controller 5.0.148.2 and Access Points 1252 and 1231; the customer have 8 laptops with Windows Vista that they present problems when to get connected to the Guest's WLAN; these same ones do not present problems when they authenticate to Employee's WLAN through PEAP. The laptops with Windows XP do not present this problem.
The users that are connected to the Guest's WLAN then they obtain correctly the direction IP through DHCP; the Guest's users can not visualize the page find salutatory Web or when sometimes they visualize it, they introduce the username and password and next do not visualize the page accordingly, and they do not connect to the Internet.
Them laptops in mention come from different manufacturers ( HP and DELL ), Windows Vista's versions ( Home Basic and Home Premium ) and wireless cards ( INTEL and ATHEROS ).
krishanmistry Thu, 11/20/2008 - 14:10
what version of IE are you running
Internet Explorer 6.0 SP1 or higher are the only browser supported for using web authentication.
Trending Topics - Security & Network
