4.2.3 Attendant Console / Pilot
Nov 17th, 2008
Is it possible to configure attendant console without any pilot groups, and only use the DN. If so, what are the implications? Thanks
Jaime Valencia Mon, 11/17/2008 - 15:35
just to add something if you have troubles we won't support your system unless configured using the guide. i know by testing that it works (kinda) but some stuff won't work or fail. so, you're free to configure it, but if you have trouble we won't support your system for any AC related matters until you configure it as explained in the AC config guide
if this helps, please rate
