QoS class class-default
Nov 17th, 2008
Hello all,
in my WAN three classes of service exists, EF, AF41 and default.
On the ingress of all WAN routers I have the following config:
policy-map from-LAN
class real-time
set dscp ef
class mission-critical
set dscp af41
class class-default
set dscp default
But I still see other traffic classes leaving the WAN interface of that router e.g. AF31, CS6, CS3, CS2
The only one I understand is CS6, as those packets generated by the router itself and therefore not remarked at the ingress.
Also if I check the policy-map, I that not all packets associated with class class-default are remarked (not remarked around 1,5% of all packets).
Any ideas?
Best regards,
Andreas
Joseph W. Doherty Mon, 11/17/2008 - 20:30
You note the policy is configured for WAN ingress? The policy looks more suitable for either LAN ingress or WAN egress. If you don't mark packets on LAN ingress or WAN egress, this might explain why you're seeing more than 3 markings.
dancarrick Mon, 11/17/2008 - 22:58
Andreas,
Can you post the output of the following?
show policy-map interface
andreas.plaul Tue, 11/18/2008 - 01:19
the policy-map is applied on the LAN ingress.
Below the output of the show policy-map interface:
FastEthernet0/0
Service-policy input: from-LAN
Class-map: real-time (match-any)
100581560 packets, 19738877717 bytes
5 minute offered rate 193000 bps, drop rate 0 bps
Match: protocol rtp
89632333 packets, 17383775517 bytes
5 minute rate 166000 bps
Match: access-group name VoIP-RTCP
10949228 packets, 2355102414 bytes
5 minute rate 18000 bps
QoS Set
dscp ef
Packets marked 100581565
Class-map: mission-critical (match-any)
18847230 packets, 4995470076 bytes
5 minute offered rate 6000 bps, drop rate 0 bps
Match: access-group name Voice-Control
8996464 packets, 707126788 bytes
5 minute rate 3000 bps
Match: access-group 120
9850767 packets, 4288343288 bytes
5 minute rate 2000 bps
QoS Set
dscp af41
Packets marked 18847236
Class-map: class-default (match-any)
429942156 packets, 346709971864 bytes
5 minute offered rate 7569000 bps, drop rate 0 bps
Match: any
QoS Set
dscp default
Packets marked 25175678
Best regards,
Andreas
Joseph W. Doherty Tue, 11/18/2008 - 04:24
I misread your original post as marking at WAN (interface) ingress when you stated WAN router ingress.
What you're doing appears correct, at least for LAN ingress to one of your WAN routers, and as you note, WAN router sourced packets could be marked differently.
How are you monitoring the other packet markings they you believe have unexpected markings?
andreas.plaul Tue, 11/18/2008 - 17:03
I am monitoring with Netflow the outgoing WAN traffic (with the markings set) and there I see packets marked with dscp values which are not generated by the router, so not only cs0, ef, af41, cs6(routing updates, but also traffic marked with af31, af11, cs2.
Andreas
Joseph W. Doherty Tue, 11/18/2008 - 17:22
I wonder if Netflow is providing you the packet's original markings.
You might also try an ingress service policy on a WAN interface and see what it records as being received for various DSCPs.
What type of WAN devices are you using and their IOS versions?
andreas.plaul Wed, 11/19/2008 - 00:26
the routers are 3745, IOS Version 12.3(7)T and the Netflow is from Solarwinds. I mean, I have to trust the Netflow to provide the correct packet markings, otherwise it doesn't make sense.
Andreas
Joseph W. Doherty Wed, 11/19/2008 - 03:39
What you're seeing doesn't make sense (if all is as you've described).
As far as trusting Netflow, you may want to "trust but verify". This especially so since your running an early 12.3 "T" version. If you have maintenance, would suggest loading the latest 12.4.
If Netflow is providing original packet markings, Cisco might not even consider this a bug, it might be a "feature". It also might be documented somewhere in order of operation of various features.
I often use an inbound policy to check incoming DSCP markings. Provides a quick method to see inbound rates for the various DSCP markings.
Policy can be simple, something like:
class-map match-any someclass
match ip dscp ef
match ip dscp cs7
match ip dscp cs6
match ip dscp cs5
match ip dscp af41
match ip dscp af42
match ip dscp be
service-policy somename
class someclass
interface serial #
service policy input somepolicy
