IVR For Auto attendent Feature
Answered Question
Nov 17th, 2008
Hi Friends
We have a customer requirement for implementing the "AUTO ATTENDENT" feature. We have to prepare the IVR for the same. The requirement is "1 should directly reach the extension number and 9 should directly reach the operator".
Pl tell how to perform this IVR. We want it very professionally.
Thanks and Regards
Karthik Sridharan
The way I setup Greetings Admin is
1. I create a CTI route point with an extension and set it to CallForwardAll to Voicemail.
2. Create a Call Handler in Unity with that Extension
3. Make you or the user who would be recording the prompts as the owner for the Call Handler. (In the Profile - select Owner - Subsriber - click Change - select the user)
4. Go to Greetings and Standard - In the Source - Select Blank - In the After Greeting Action Select Send Caller to - Scroll down and select Greetings Administrator.
It is setup now, you can call the extension you created and get to the IVR for Greetings Admin. To record Greetings for each Call Handler you would need to know the extension of the Call Handler and you the person recording prompts needs to be the owner for those Call Handlers.
If you want more than one users to be able to record prompts, then add them to a Public Distribution list in Unity and select the list as the owner in Step 3.
Let me know if you have any questions.
JoeL
Overall Rating: 5 (1 ratings)
karthiksr Tue, 11/18/2008 - 20:21
Thanks Joel
We are going to configure in the Unity.Thanks. Yes i knew on how to configure. But we dont have the IVR - (the automated voice response) audio file to upload. How to make one with the above said requirements.
Karthik Sridharan
Correct Answer
JoeL
