IPsec tunnel between PIX and 3745 Router
Nov 17th, 2008
Hi every one.im trying to run L2L vpn with ipsec tunnel between my pix and 3745 router.my problem is that tunnel goes up only when traffic flows from one direction.let me describe my senario.
ethernet 1:connected to host A
Host A:
ethernet 0( to R3745
ethernet 0/0 ( to pix
etherb=net 0/1( to Host B
Host B:
PIX Version 7.2(3)
interface Ethernet0
nameif outside
security-level 0
ip address
interface Ethernet1
nameif inside
security-level 100
ip address
ftp mode passive
access-list nonat extended permit ip
access-list tr extended permit ip
access-list ping extended permit icmp any any
pager lines 24
mtu outside 1500
mtu inside 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list nonat
access-group ping in interface outside
route outside 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ipsec esp-3des esp-sha-hmac
crypto map crymap 1 match address tr
crypto map crymap 1 set peer
crypto map crymap 1 set transform-set ipsec
crypto map crymap interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect icmp
service-policy global_policy global
tunnel-group DefaultRAGroup ipsec-attributes
isakmp keepalive threshold 10 retry 2
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
version 12.4
crypto isakmp policy 10
encr 3des
group 2
crypto isakmp key ***** address
crypto isakmp keepalive 10
crypto ipsec transform-set sec esp-3des esp-sha-hmac
crypto ipsec profile sevan
set transform-set sec
crypto map map 10 ipsec-isakmp
set peer
match address 110
interface Tunnel10
ip unnumbered Ethernet0/0
tunnel source Ethernet0/0
tunnel destination
tunnel mode ipsec ipv4
tunnel protection ipsec profile sevan
interface Ethernet0/0
ip address
interface Ethernet0/1
ip address
ip policy route-map sevan
ip http server
no ip http secure-server
ip route
access-list 110 permit ip
route-map sevan permit 10
match interface Ethernet0/1
set interface Tunnel10
***when i ping host B from Host A ping is working and tunnel on Router 3745 goes up but when i do not ping host b from host A after some secondes tunnel goes down and if i first ping host A from host B ping never works and tunnel never comes up.so when traffic is generated from pix Lan every thing is ok but when traffic is generated from Router Lan nothing about vpn works.i dont know why this senario works in this way!!!???
ajagadee Tue, 11/18/2008 - 05:34
I dont think this set up is going to work. The reason being, your tunnel destination on the router is an ASA and ASA do not support GRE Tunnel termination. You have to terminate a GRE Tunnel on a router.
Reconfigure the router without using the GRE Tunnel interface and test the tunnel.
*Pls rate if it helps*
