Platinum QoS profile limits data traffic
Nov 18th, 2008
I have WLC which controls a WLAN that hosts data traffic and VoIP traffic.
I have enabled Platinum QoS profile and the throughput of the WLAN decreases to approximately 10 Mbps (With bronze QoS profile throughput was like 22~25 Mbps).
I would like to know how does the QoS profile limit the throughput of the WLAN? WLC gives a warning that data traffic will be affected but that doesn't tell much about the actual mechanism of traffic limiting.
I used iperf software sending UDP data @ 500 Mbps to measure the throughput.
Olli Karhunen
gamccall Tue, 11/25/2008 - 08:19
Is it absolutely necessary that your data and voice clients be on the same SSID? Seems like things would work better if your voice clients were on a platinum SSID and your data clients were on a different bronze/silver SSID.
