11-18-2008 12:30 AM - edited 02-21-2020 03:06 AM
How can I clear counters on my PIX Firewall 515E ver 6.3(4). There are alot of input errors on my inside interface. Please advice.
11-18-2008 01:00 AM
pix(config)# clear counters
or if you want to clear only a particular interface
Jon
11-18-2008 02:15 PM
It doesn't work on PIX FIREWALL 515E version 6.3(4)
11-18-2008 02:22 PM
Bernadette
Apologies, it is not "clear counters" it is "clear counter".
You also need to make sure you are doing this in config mode -
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/c.html#wp1091147
Jon
11-18-2008 05:24 PM
As Jon indicated, you need to be in config mode,
try - pix(config)#clear interface to reset all interface counters.
for especific interface
(config)#clear interface ethernet0
etc..
Rgds
Jorge
11-18-2008 06:06 PM
it doesn't work.
11-18-2008 06:37 PM
did you go into config mode and enter the command?
e.i
pix>enable
pix#config
11-27-2008 03:59 PM
"clear interface" but that might not correct the issue, when you get CRS errors that indicates that there is an issue with cables or problems with speed or duplex of the neighbors devices.
