Collin Clark Tue, 11/18/2008 - 06:29
  • Purple, 4500 points or more
"With a forwarding rate of up to 400-Mpps distributed and 720-Gbps total throughput, the Cisco 7609 provides performance and reliability with options for redundant route processors and power supplies."
From http://www.cisco.com/en/US/prod/collateral/routers/ps368/ps367/product_data_sheet09186a0080169ead_ps368_Products_Data_Sheet.html
Hope that helps.
Mavrick25 Tue, 11/18/2008 - 07:09
Hey,
Thanks for the information.
I really appreciate...
Mavrick25 Tue, 11/18/2008 - 07:18
Collin,
Sorry to bother you, could you help me out one more time..
The console port on my supervisor card is broken...
If I install the redundant supervisor card then take out the one that is broken nothing will happen right..
I mean, the IOS ect ect should be transfer automatically on the new card right?
Please and thank you
Collin Clark Tue, 11/18/2008 - 07:39
No, you must put the IOS on the Supervisor! I would make sure the config is synced and copy it to flash on the new Sup just in case.
Mavrick25 Tue, 11/18/2008 - 08:29
Collin,
Is there any documentation on the internet that could help me out..
Supervisor on a 7609 never did before...
this router also peers with our gateways so I don't want to mess anything up..
thanks in advance...
